Colo_NativeExplorerSep 24, 2015TST 507I just received my TST 507(non flow thru) and the directions say to set the psi high and low, the tire inflation is 80psi per the FW sticker, so what should the high and low be? Also the temp high and...Show More
agesilausExplorer IIISep 24, 2015Ford uses 65 psi as it's low pressure alarm point, maybe 95 for the high
