I just received my TST 507(non flow thru) and the directions say to set the psi high and low, the tire inflation is 80psi per the FW sticker, so what should the high and low be? Also the temp high and...
I think it is on their website that says to set 20% on the high end and 10% on the low end. There is no low temperature setting. They recommend leaving the high temp set as at came from them. I think that is 158F per Michelin recommendations.
