Colo_Native
Sep 24, 2015Explorer
TST 507
I just received my TST 507(non flow thru) and the directions say to set the psi high and low, the tire inflation is 80psi per the FW sticker, so what should the high and low be? Also the temp high and...
Old Duck wrote:
I watched their video before programming mine. I believe it said the over PSI SHOULD NE 20lb above your normal, the under PSI should be 10lb below. That's what I've done and it's worked well on the trip we are on.
