Colo_Native
Sep 24, 2015Explorer
TST 507
I just received my TST 507(non flow thru) and the directions say to set the psi high and low, the tire inflation is 80psi per the FW sticker, so what should the high and low be? Also the temp high and...
larry barnhart wrote:Shouldn't your air pressure be at the correct reading when you first start out? Surely you're not starting out low and letting the heat buildup get the pressure to the correct reading. Bad idea. I start out with the tire pressure set where I want it to be and allow for heat and pressure buildup. I plug my monitor in while I'm preparing for departure. That gives the tire sensors time to communicate with the monitor before setting out.
I have found out during cold temperature's as we hit the road I wait for a few miles to warm up the tires and bring up the air pressure before turning on our TST monitor. wife doesn't like extra noise. I have it set for this to happen.
chevman
