valhalla360
Jun 10, 2021Navigator
If you can get the truck 90 degrees to the trailer without hitting the cab, should be no problem swinging a U-turn in the cul-de-sac.
Your other option, is quite viable also. I assume it's low volume so traffic shouldn't be a problem to back down the road. Just take your time. Since 5th wheels are slow to start turning when backing, you generally have plenty of time to correct. 660ft isn't far. Worst case if it starts to get away from you, pull forward 20-30ft to get it in line and start backing again.
Do it a few times and your skills will improve.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
