SweetLou
Jun 13, 2021Explorer
valhalla360 wrote:
If you can get the truck 90 degrees to the trailer without hitting the cab, should be no problem swinging a U-turn in the cul-de-sac.
Your other option, is quite viable also. I assume it's low volume so traffic shouldn't be a problem to back down the road. Just take your time. Since 5th wheels are slow to start turning when backing, you generally have plenty of time to correct. 660ft isn't far. Worst case if it starts to get away from you, pull forward 20-30ft to get it in line and start backing again.
Do it a few times and your skills will improve.
With out reading all this stuff you don't need to know, just back it down as Valhalla says. It's not rocket science here and have a spotter as you back so you don't hit a parked car. I do it all the time and I am good enough to not really need the spotter. I use one just in case a neighbor pulls out of driveway. Easy. If you can't back this down with any kind of trailer, I would rethink Why I have one.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
