jkwilson's avatar
jkwilson
Explorer III
Jul 13, 2017
Turning Radius -- Can it be calculated/estimated?
If this question should be in towing, I apologize. I don't have a feel yet for what the spirit of forum distribution is here.
My property has a branch off the main driveway that goes to the barns. Pretty tight area back there for turning around because of topography. For farm equipment, I usually just open a gate and turn around in the pasture so I can get the rig facing out the drive. Since my 5th wheel is going to be stored back there, I need to make provisions for turning it around that don't involve an off-road excursion or cow manure on the tires.
I plan to build a loop in the drive which will involve moving fence and adding some gravel. My plan was to just turn the rig around a few times without going 90 degrees to see what a reasonable turn is. Then I'll mark the grass and make a road. I'm planning on a kind of offset teardrop so I can turn slowly at first when I'm near a building, then once the back end of the trailer clears I can turn faster.
But what if I get a bigger trailer or different truck? I don't want to do it all over again. Any thoughts on how adding length from pin box to axle would affect "comfortable" turning radius? Or is there a rule of thumb that would guide me? I don't want to go crazy since the further I extend the loop, the deeper the gravel will need to be to keep the road level from side to side.
  • Do a google search for turning templates for trucks. You should be able to find something similar to the length you are working with.
  • troubledwaters wrote:
    Can you calculate it - yes; but it would be so difficult that you don't want to. (it would involve turn radius of the truck, distance from wheels to hitch, distance from hitch to axles, etc.)
    Better to just go to a open parking lot and chalk mark it on the pavement and measure the diameter you need.
    Add to that how acute an angle you can get with the truck and trailer and keep the front cap from hitting the back of the truck (variables: front cap design, position of pin box to front cap, position of hitch in truck bed, itch-to-cab distance, etc.). Every truck/trailer/hitch combo is different.
    Rob
  • Can you calculate it - yes; but it would be so difficult that you don't want to. (it would involve turn radius of the truck, distance from wheels to hitch, distance from hitch to axles, etc.)
