99x's avatar
99x
Tv antenna
I am looking to update the tv antenna on the camper,it has a Jensen omni direct antenna and does not work very well,had better reception with our old camper and bat wing antenna. Looking for input. Thanks
  • I also have an omni on my FW. I left it intact, due to it being for the radio, as well as the tv.
    I bought the replacement head Jack, that is supposed to replace the batwing head. I fasten this to a two piece aluminum pole, and use a couple of stretch cords to fasten it to my FW ladder.
    I have it about 4' above my roof, using the supplied coax. It works great. I just fasten the coax to my outside cable hookup, right near the ladder.
    Jerry
  • The Jensen omni is crap, I also have one and hate, hate, hate it.
    For me, the problem with the conventional "Bat-Wing", is the ceiling is too high for even me (6ft plus) to reach it.
    Wingard makes (used to?) a motorized Batwing. That deploys and turns with a motor. I thought (hard) about that, but ended up moving on.
    Testing done by people in this forum suggests to me that the Jack Omni would work (at best) marginally better then the Jensen.
    Both suffer from the same problems, size and height. No antenna mounted low to the roof is going to work as well as an antenna with more height.
    Also size matters, small antennas don't work as well as large antennas.
    I ended up with an Omni sold by Radio Shack. This is much larger then the Jensen or Jack. But I mount it on a separate push-up pole on the rear of the trailer. Obviously not something I would do for an over-night stop.
    There is a "old tech" Antenna that should work well, it's two crossed elements that fold up and go into a tube. This design has been around for years, but I believe it is still sold
