ng2951
Sep 19, 2020Explorer
...Also, if one has Schwintek mechanisms on slides, it is not advisable to partially extend the slide and then retract it. It must be fully extended before it is retracted to maintain alignment.Not entirely true. The way you resync the slideout is to retract the slideout 10" and then fully extend them, holding the extend button for 3 to 5 seconds. You generally repeat this 3 times.
Lippert and some RV shops recommend lubing the bearings and gibs every 6 months with CRC Power Lube with PTFE.
About Fifth Wheel Group
