KD4UPL
Nov 02, 2013Explorer II
Impulse24 wrote:
rhagfo, Oh great one do you think I drive an empty truck and trailer? You are slipping in you attempt to be sarcastic...
KD4UPL, I guarantee if you work out your MPG on every fill up there will be a difference in the results. There being only an average can be used to evaluate a trucks fuel economy and overall MPG. If you are claiming you never get less than 10 mpg, you are driving a 3/4 ton, the Duramax in a 1 ton and c400 Kodiac deliver no more than an averaged 9.8 mpg. Could it be your driving a 3/4 ton and mostr of the time your truck is bobtail?
As for a Diesel achieving you
It's a dually, crew cab, 4wd, with an aluminum flatbed and under and over bed mounted tool boxes. I do indeed hand calculate my mileage for every tank of fuel. I have since I bought the truck new.
The first tank home from the dealer (400) miles was 17 mpg.
After the work bed went on it weighs about 8,500 and I generally get between 15 and 16. If I put my Fleetwest slide in tool box in the bed I get about 12.5 at about 11,000 pounds. With my truck camper in the bed, grossing about 13,200, I get about 11 mpg. If I hitch up the boat with the camper on, grossing about 18,000 I get around 10.5. Pulling my equipment trailer and hauling steel, skid steer, mini-ex, etc. I gross around 24,000 to 25,000 and get 10 mpg.
Those are my numbers. I don't have a FW but I hope it gets the OP some idea of how widely loads, profile, and weight can drastically affect MPG.
About Fifth Wheel Group
