Golden_HVAC
Dec 08, 2015Explorer
If you are towing a trailer, there is a maximum of only about 20 amps leaving the Truck towards the trailer for charging it's battery, and perhaps another 20 amps for lights and such.
The brakes can use 20 - 30 amps (two or three axle) at the very most, with oversized #10 gauge wire, but it is such a short term - only 10 - 20 seconds during a 10 minute drive.
A normal 100 - 130 amp alternator can run everything on the trailer. Unless you upgrade the wiring between the trailer to say #8 wire, then it might possibly carry as much as 30 amps.
It would be better to install a solar system on the trailer, and not worry about how many amps the engine puts out.
SunElec.com
$229 will buy a 140 watt solar panel with a aluminum frame. 6" long 2" angle aluminum will make mounts for the roof. UV rated direct burial romex is rated for the sun, rain, and snow!
Fred.
SunElec.com
Fred.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
