laknox
Aug 25, 2017Nomad
grizz02 wrote:
I noticed a leak on the right side if standing behind looking at camper behind axel I'm thinking grey water tank looking for best way to remove under belly and if anyone has had this problem. Also saw that Gas line is getting pretty rusted has anyone replaced one of these. Thanks for any tips
2 ways to go about this. One, assuming you have the plastic coroplast underbelly, simply cut a small inspection hole on 3 sides (uncut side to the front) and take a look around to see where the leak is coming from. You can either then enlarge the hole to work on the leak or remove the entire sheet. "Fix" the hole using Eternabond or Gorilla tape. Two, simply unscrew an entire sheet of the belly covering. Will likely take a couple people to maneuver it, though.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
