laknox
Feb 23, 2018Nomad
That looks an awful lot like a hex screw with a bunch of sealer around the head. Might want to scrape it off and get a better look. An easy way to check without removing the belly panels is to cut a small access port. Cut it with 3 cut sides, leaving the "hinge" side to the front of the trailer. You can then swing it down to have a look around, then use some Gorilla tape, or the like, to seal it back up. Also, are you sure that the duct is between the floor and the belly covering?
Lyle
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
