Dayle1
Feb 23, 2018Explorer II
Old-Biscuit wrote:
Those are 'self penetrating' fasteners (nails) used by Ramset/Hilti Guns which use a .22 caliber shell to 'shoot' the fastener in.
You COULD grip them with a pair of vise grips and tug/yank/twist to try and remove...good luck with that
OR
Yea, those are hardened steel, unlikely to pull out and difficult to cut off.
So a small access port is the best idea if you know where to cut it. If you need a larger access area, you can cut the coroplast around each nail leaving it intact. Then reinstall the coroplast with new metal screws and washers at different points. Also tape over all cuts in the coroplast.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
