Dayle1
Feb 23, 2018Explorer II
tommygun714 wrote:
Hi,
I need to look behind the underbelly of the trailer for a disconnected heater duct on my new 2018 Cougar 25RES
The main heater duct is right up against the plywood floor and the floor vents are simply cut thru the plywood, so there is nothing that can be disconnected. There are one or two round ducts that connect the main duct to the upstairs floor vents in the bathroom and bedroom. Those could be disconnected, but they are accessed from the basement NOT the underbelly. The rear wall of the basement storage area should be held in place with a few screws.
Every fifth wheel I have seen, the underbelly area does not provide access to the furnace ducting. There is a second waterproof barrier across the TOP of the I-beams and the furnace duct is above it. In fact your picture shows that second layer, it runs the full width of the trailer and a flexible fabric while the coroplast just runs across the bottom of the I-beams.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
