Car1800
Apr 14, 2021Explorer
Uneven Bearing Temp
I have run into a situation that I have not seen before. The bearings on the rear axles are about 30-40 degrees warmer than the front axles using temperature gun. I have pulled the bearings and no problems. They are not overheating just running warmer. I have never seen this much difference before. The thing that changed is the truck, from a 2011 Ram to a 2019 Ram and a B&W hitch. The truck is higher of course. The camper is sitting 2 inchas higher in the front by using a level and tape measure. Is anyone seeing higher temps on their rear axles under this type situation? The rv has Trailaire suspension.
