John&Joey wrote:
If you're worried about the fridge being out of level then all I got to say is I would be more nervous about the rig rolling away because you found one extremely crappy parking lot to stay in, and a much better one is just a few miles down the road. Fridges came a long way since the 70's when it comes to lifespan.
Rig rolling away.....?????
Wheel chocks...first ON/Last OFF
Trailer should have chocks BEFORE unhooking trailer every time
RV absorption fridges have come along way........????
Only with the bells & whistles
The cooling unit tubing has gotten thinner therefore many cracked tubes/ruined cooling units on the newer fridges.
Lots of cooling unit replacements going on with modern rv fridges OR swapping out to residential fridges
Many, many older fridges are still out there running just fine because the tubing is more robust.
 mike-uswest  wrote:
 I do unhook the cord, because my brakes on the trailer evidently check in about every minute, and it makes a very quiet click. I can only hear it if I am right by the brake on the trailer, but my wife can hear it and can't sleep.
Your 'charge/power' circuit on that 2003 Dodge is hot all the time so you should unplug your trailer cord BUT that your brake circuit should only be getting voltage thru your cord when you use the truck brakes or use the manual lever on brake controller (or via emergency break away switch which is thru trailer battery system only).
So you should not be hearing any 'click' at trailer brakes especially one that is repetitive. Power is ON or OFF.  Magnets are energized or not. But that is only when brakes are applied.
You should investigate HOW that is happening.
