- wilber1Explorer
Michelle.S wrote:
Wilber1, if you're referring to my post, please re-read it. If no electric (read Shore Power) I'll disconnect because the TV bats would be in the same circuit as the RV bats if left connected, thus if too much power was used could also drain the TV bats.
I wasn't referring to your post in particular but I do agree that you might be drawing the truck batteries down at the same rate as the house batteries if not connected to shore power. Might be a good idea to disconnect if you anticipate using heavier loads (ie furnace). - Michelle_SExplorer IIIWilber1, if you're referring to my post, please re-read it. If no electric (read Shore Power) I'll disconnect because the TV bats would be in the same circuit as the RV bats if left connected, thus if too much power was used could also drain the TV bats.
- wilber1ExplorerI never have disconnected but don't know if I am right.
Some questions.
How would being hooked up drain the truck batteries without doing the same to the house batteries?
Being part of the same DC circuit, wouldn't the converter/charger provide the same protections to your truck batteries as it does to the house batteries and circuits when hooked up to shore power?
Just asking. - Michelle_SExplorer IIIIf we're stopping overnite without electric I'll disconnect Truck/Trailer, don't want to take the chance of dead truck batteries. Now stopping overnite with Electric, I won't disconnect and let the trailer converter add a little extra charge to the truck batteries. Have not had a single problem doing this.
- one_strange_texExplorerThe technician in my walk through for the previous 5th wheel advised unplugging the umbilical from the truck before hooking up to shore power. I occasionally forgot it and it seemed to coincide with blowing the fuse on the 12V trailer circuit in the truck, but not every time. I received no such advice on my latest 5th wheel, often leave both plugged in when reaching a site until disconnecting the truck from the hitch and have not detected any problems. If you overlap the connections, many of the clocks, etc. that run off the 12V trailer system do not have to be reprogrammed.
- LantleyNomadI unplug to keep the truck isolated from the pedestal/trailer.
I do not want the trailer to drain the truck battery due to a malfunction of some sort.
Unplugging is cheap easy insurance that the truck electric cannot be impacted by the trailer electric - azdryheatExplorerHmm, I never considered disconnecting from the truck. No problems so far.
- LearjetExplorer
GordonThree wrote:
It's also neat if I turn the trailer marker lights on, the rooftop markers on the truck come on too.
And on the DRW models you get the fender side markers too :) - KD4UPLExplorer IIThe OP said he would be plugged into shore power. Why all this talk of draining the battery? I always leave mine plugged in when on shore power. That way the camper converter keeps the truck battery charged. I have a Chevy so the line stays connected with the key off. I like it this way. Between dome lights, stereo, ham radio, etc. I don't mind having the truck battery on the converter while parked.
- 2oldmanExplorer IIDoes no harm to my setup. I never like doing things I don't need to do.
About Fifth Wheel Group
