- neal10aExplorerThe trailer battery charge line power from my truck is thru a relay that is activated when the ignition is start or run. Other wise their is no power to the trailer. However when the tail and brake lights are active when the truck lights are on. I believe all late model trucks are that way-- at least that is how Ford is wired. If the truck is running while hooked to the trailer and the shore power is connected to the trailer, the trailer battery charger is active which will not do any damage to the truck alternator or visa versa. The alternator/charger will see a net reduced load which does no harm....
- joebedfordNomad III unplug when I'm dry camping overnight. Having run down the truck batteries by mistake, I learned my lesson.
- JaycoAngelExplorerThank you everyone for your advice!
We will unplug! Just in case - Butch50ExplorerOn Fords they disconnect trailer power when you shut the key off (or at least they used to). Rams do not disconnect power and I believe GM also stays on. I put in a disconnect relay in my Ram so when the key is off my power to the trailer power is disconnected.
Bargman Battery Isolator - ScottGNomad
time2roll wrote:
As long as the trailer is plugged in to the pedestal, unplugging from the truck will not matter.
X2. - LwiddisExplorer III always unplug. Just don't want an unlikely issue with draining the TV battery or electric spike also frying the TV but its very rare when I hook up to shore power.
- VeebyesExplorer III am a firm believer in Murphy's Law. With that in mind I try to be in the habit of unplugging, even if it is only a Walmart overnight.
- As long as the trailer is plugged in to the pedestal, unplugging from the truck will not matter.
- coolmom42Explorer IIWe unplug.
*Protection against electrical surges/lighting--admittedly not likely to happen, but very bad if it did.
*If tow vehicle kill switch doesn't work like it's supposed to, tow vehicle battery could be drained. Also unlikely but really annoying.
It's mostly a habit, but 15 second insurance is cheap. - Roger10378Explorer III unplug now. I didn't until I had converter failure. With the trailer connected to the truck I didn't realize the converter was not working until morning when the slides would not retract and the truck would not start. Now I make sure to unplug.
About Fifth Wheel Group
19,016 PostsLatest Activity: Jun 11, 2025
