Irelands_child
Jan 25, 2016Explorer
This spring will see someone's version of the cross type stabilizer. Since last year was the first summer for our 343RL '14 High Country 5er, I opted to use a couple BAL rear scissor stabilizer jacks right at the drop down area of the frame (the Cougar 327RES has a similar if not identical Lippert frame). Those jacks plus the BAL chocks each side between the tires removed probably 90% of the wiggle which is probably about as good as you can get without the JTs or a concrete foundation and the tires 100% off the ground. I also minimized with built up wood pads the amount extension of the rear jacks and front levelers.
About Fifth Wheel Group
