Cummins12V98
Mar 28, 2016Explorer III
"From internet chatter it seems the score is 2-2. There are 2 reports of Andersen Hitches that deformed and were replaced with redesigned parts in the Cummins thread. And in this forum Cummins12V98 reports two B&W's had base deformation resulting in replacement with redesigned parts. Both companies stood behind their respective products and satisfied their customers."
B&W's was NOT a design failure as I made clear earlier as Andersen's clearly is.
B&W's design did it's job with the 18K Companion when used in a truck that it was originally designed to be used in. My 11 and my Dad's 12 had much weaker beds and the ribs did not align under the strongest part of the base. All that was NOT B&W's design problem but they did see that the newer trucks are built different and they re designed the Companion to work with the newer trucks and is now rated to 20K.
About Fifth Wheel Group
