Cummins12V98
Mar 28, 2016Explorer III
WTP-GC wrote:Cummins12V98 wrote:
B&W's was NOT a design failure as I made clear earlier as Andersen's clearly is.
B&W's design did it's job with the 18K Companion when used in a truck that it was originally designed to be used in. My 11 and my Dad's 12 had much weaker beds and the ribs did not align under the strongest part of the base. All that was NOT B&W's design problem but they did see that the newer trucks are built different and they re designed the Companion to work with the newer trucks and is now rated to 20K.
So B & W was not at fault...it was someone else? Hmmmmm....
Did B & W clearly identify the spec requirements for truck beds and frames that their hitch was compatible with? Did they tell customers what truck(s) could be used? Why would they have redesigned their product if they didn't have an issue? Could it be that the hitch was over-rated (even if the truck was the determining factor)? Did truck bed/frame makers change overnight and left the fifth wheel hitch market hanging, or were hitch makers continuing on with their product design even though there were problems?
All of the above is basically the same "type" of questioning that's been brought up over the Andersen UH. But rather, it looks like B & W and Andersen chose the same route: PRODUCT AND DESIGN IMPROVEMENT. They both observed issues and made the necessary improvements to their product line. Good work by both groups.
Did you read what I said? B&W designed the 18k to work with the trucks on the market at the time. It worked VERY well. Then the CONDITIONS changed. Then they designed a different base to work with the newer trucks. Design had nothing to do with the hitch being upgraded.
Andersen did not build their Ultimate to perform up to the ratings THEY list their hitch to perform within.
I am just pointing out the facts. I will say it again Andersen does make a Quality product!!! There are things about the design that I don't care for and think people should know about these and then make an informed decision.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
