WTP-GC's avatar
WTP-GC
UPDATE - Andersen Ultimate Redesign
As it has been discussed on here, Andersen recently redesigned their Ultimate 5th Wheel hitch. There's been wide speculation regarding why they did this, or if that was an indication that the original design was insufficient. As an owner of the "lowered" version, I emailed them to discuss whether or not I should be seeking a replacement for my hitch in light of the redesign. They responded back with a long email, which can be summarized below:
1. The "lowered" version did not have a redesign, due to being shorter and having reduced leverage points.
2. They acknowledged that the redesign of the regular hitch was due to a couple of minor incidents (as we've seen) where the ball coupler shifts about 3 degrees in heavy tow combined with emergency braking situations. The intent of the redesign was to be able to accomodate the heaviest of trailers.
3. They've sold over 18,000 ultimate hitch units since 2011 and have had ZERO failures.
4. They've upgraded their warranty to a Lifetime Warranty.
I'm only providing this information for those who may be on the fence about purchasing one; not meant to be a sales pitch for them. If someone told me they've sold over 18,000 units without failure and only a couple very minor issues, then my confidence is boosted.
  • It's naive to think that companies never improve their designs and that they make the perfect design the first time and use that design forever.
  • No popcorn will be needed as long as the comments remain on topic and do not become personal in nature. So far-so good. Keep it up! :)
    Barney
  • Yep, I got to agree with guys above, a failure is when the hitch can no longer be trusted to stay in service.
    I think this is a set back for them, and hope their correction, and taking care of customers keeps them moving forward.
    Pass the popcorn SabreCanuck!
    Jerry
  • Cdash wrote:
    Good information.
    #3 - I'm not buying the "no failures" line.
    If a hitch bent enough that it needs to be replaced, that IS a failure. It may not be a "catastrophic failure" that resulted in a separation of truck and trailer, but in its duty to pull a trailer within rated limits within reasonable expected conditions (i mean not getting rear ended) without damage, it failed. Plain and simple.
    There isn't a component in any of our setups that should need to be replaced after a panic stop, except for maybe a glass that falls out of a cabinet.
    I hope they get things sorted out and don't continue to see "minor incidents".
    That's the way I feel about it. If something happens to my hitch and the company think it needs to be replaced, that's a failure. Like you say, not a catastrophic failure, but a failure all the same. If Anderson didn't consider it a failure, they wouldn't replace it with the new design at no cost.
  • Maybe they need to start doing more than their vertical crush test? Or are they letting people out on the highway test the fore and aft strength?
    Chris
    Good information.
  • Good report! Thanks for sharing...
    I've called Andersen a few times and the have always been very willing to speak candidly about their products. I spoke with one of their engineers about the Andersen Weight Distribution hitch and he flat told me that it works best with a light tongue weight trailer.
    I also emailed them about the Andersen Ultimate Fifth wheel gooseneck connections comparability with the Drop N' Lock gooseneck hitch and they replied with yes...and commented on what a neat design the Drop N' Lock is. Which I agree. The Drop N' Lock is a very smart design. Anyway...there I go digressing again.
    Thanks for the feedback...I really like the Andersens Ultimates design and their Enhanced Aluminum version should resolve the minor issues it's had.
    Thanks!
    Jeremiah
