retispcsi
Sep 30, 2014Explorer
If you have the Ram factory mounts the hitch mounting equipment is already installed under the bed and attached to the frame. First as said before the goose neck may not be the best way to go with a fiver. Now all you have to do is order a B & W hitch #3600 or I believe Curt has one also for your factory mounts. You will need to cut out the mats and cover so your hitch base plate will sit the way it was designed to. B & W is my favorite.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
