Bayley wrote:
UPDATE: Well I found some new take off 275/70/18E's from a 2015 Ram 2500 for a heck of a price on Craig's list.
I'm going to make the change but I now have another question:
A spare doesn't come in the deal so is it alright to use my current 17" spare? I called a tire dealer and they said it wouldn't be an issue if I didn't run it in 4 wheel drive.
anyone have any experience with this?
Thanks again for the help!!
Any truck with limited slip axles require the same diameter tires on the same axle. Two different diameter tires will damage the limited slip. If you were going to use a smaller spare, you'd have to move one of the front tires to the rear and mount the spare on the front. And you couldn't use the front wheel drive.
