RobertRyan's avatar
RobertRyan
US 5th Wheel Complance in Australia
There are many hurdles a US compliant 5ver has too go through to be even registered here. This is a 36ft Heartland Eldridge . Owner gives a breakdown. Then after all this if you have too sell it, you have too overcome Australian reluctance too buy 5th Wheeler, whether small or large..Locally made ones are already compliant
This luxury 5th wheeler is up for sale. It comes with 2 bedrooms, 2 bathrooms, living area and the kitchen. It has plenty of storage and it sleeps 9 people. Made compliant to Australian standard in November last year, this 2017 model Elkridge comes with all the bells and whistles. It had all the Electrical 110V wiring changed and upgraded to 240V, all the gas piping was changed to fit the Australian standard as well. Exterior lighting, such as clearance lights, indicators and rear tailgate lights were also upgraded to meet the Australian standards. Some appliances had to be changed to Australian appliances, others were certified by the energy safety inspector.
According to the manufacturers specification, this 5th wheeler's unloaded weight is 4298kg with the crying capacity of just short of a tone. Because the ATM exceeded the 4,500kgs, the limit set by the Australian Design Rules (ADR), the original axles, electric brakes and suspension had to be replaced with 2x 3000kg air brake axles. As the result the ATM has been upgraded to 6,000kg which is almost 800kg higher than the manufacturer's specification. Suspension was also replaced by the heavier duty equivalent. The axles had to be moved backwards to meet the ADR requirements, rules that refer to the rear overhang.
  • fj12ryder wrote:
    I would think that a trailer would have most of the same issues of limited Off Road ability as a 5th wheel. Why would a trailer be better?
    No unlike the US there is specialist Off Road trailers that have a frame and a truck / SUV like suspension
    Taking it too extremes
  • I would think that a trailer would have most of the same issues of limited Off Road ability as a 5th wheel. Why would a trailer be better?
  • fj12ryder wrote:
    Geeze, and I thought the US had too many regulations, this makes them look like China. I mean, 6600 lb. axles on a trailer that weighs less than 10,000 lbs., and air brakes to boot! That's just plain ridiculous. No wonder no body want to build for the Aussie market, and things are prohibitively expensive there.
    Locally built 5 vers no problem. That is just getting them registered. Wheels relocated too stop kangarooing.
    Most of those ADR regulations come from heavy truck regulations
    Tow vehicle type is a pretty minor problem compliance is a major one.
    Then you have too win over local buyers too the concept of a 5Ver. They get turned off as well they hear that they have limited Off Road abiity
  • Geeze, and I thought the US had too many regulations, this makes them look like China. I mean, 6600 lb. axles on a trailer that weighs less than 10,000 lbs., and air brakes to boot! That's just plain ridiculous. No wonder no body want to build for the Aussie market, and things are prohibitively expensive there.
  • Slownsy wrote:
    And your point is ?
    Frank.
    Bleeding obvious.as the English would say. You literally have too rebuild it too get it registered
