laknox
Dec 06, 2015Nomad
12lightsacrossthebay wrote:
Hello Friends, we are in process of upgrading from 23' Thor Scamper TT to a fifth wheel to go cross-country. We are newbies with just 1 year of trailering experience. Our TV is 2009 GMC 2500HD Duramax, (40k miles) K&N air Intake and EGT Gauge. full fifth wheel accessories. 9200 GVWR. 3.73 rear gear ratio. Looking at ~ 30' unit. Any advantage to gooseneck attachment other than being able to use the truck bed when unhooked? Thanks kindly for advice regarding this question. Carl & Peggy
A lot of mfrs =expressly= void a warranty if a GN adapter is used. Lippert =will= warrant =some= frames if a Reese Goosebox is used, though. You need to check with the mfr, and get the answer IN WRITING!
I'm in the same size boat as you, wanting to stay around 30'. My top 2 choices are the Jayco Eagle HT 27.5RLTS and the KZ Durango 1500 D284RLT. Both are "half-ton-towable", but don't let that fool you; they really need a 3/4 ton to comfortably tow them. The Jayco Eagle HT's all gross out at 9,950 lbs and the Durango 1500's gross out at 10,500. While the KZ is my #1 choice overall, the fact that there's exactly 1 KZ dealer in all of AZ means that I'll likely go with the Jayco.
FWIW, I use the B&W Turnover Ball base with their Companion FW hitch and love them both. B&W makes several different versions of the Companion, so there's one that will fit your needs.
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
