RV_wanderer
Sep 04, 2013Explorer
My Dometic fridge was under a recall about 4 years ago for a fire hazard. The "fix" was to install a metal cage around the burner area, including a thermistor to sense heat in case of a fire in which case the propane supply would be cut off. I feel comfortable with this although it's not a perfect solution. A better solution would have been to replace the cooling unit with one with proper welds but the manufacturer wouldn't spring for that.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
