2012Coleman's avatar
2012Coleman
Explorer II
Mar 20, 2018
Using The B&W Companion Slider
Brought my new GD Reflection 303RLS home yesterday - towing with RAM short bed and a B&W Companion manual slider. Needed to slide the the trailer back to get into driveway, so I moved the lever and eased on the gas, but not a lot of sliding.
So I applied the trailer brakes by squeezing the brake controller and them moved ahead slowly until it slid back and locked in. I didn't anticipate having to slide it until I got home, so hadn't consulted the manual - but doing so afterwards, not a lot of instruction on actually using it while connected.
Did I do this correctly, or is there a better way?
  • markc wrote:
    laknox wrote:
    I have zero slider experience, but I recently stayed at a Holiday Inn, so I can tell you that you did it correctly. :B
    Lyle
    Like the John Deere A !!
    Thanks! Sadly, it no longer looks as good as it did in the pics I have on my FB page. :-(
    Lyle
  • Hi everyone. I have a 2014 Ram 2500 with the ramboxes. I'm currently pulling a 33ft fourwinds travel trailer. We would like to buy a fifth wheel, but I want to be sure I can get the right setup for the hitch. Has anyone had success with that. I was told to use B&W turnoverball gooseneck hitch and add a B&W companion hitch with slider for the short bed. Any thoughts or pic's would be appreciated.
  • Never had to use my slider but I would have done just what you did, great job. Be safe and happy travel.
  • You did exactly what I have done many times and it works fine!
    Lyle
  • If I remember correctly the actual instructions state to chock the wheel and hold the trailer brakes and slowly extend/retract the hitch during sliding procedure.
    Sounds like exactly what I would have done to me....
  • I have zero slider experience, but I recently stayed at a Holiday Inn, so I can tell you that you did it correctly. :B
    Lyle
  • MFL wrote:
    Nice thing about a B&W, is customer service. A quick call to them, gets a real person, that has the answers, or will quickly connect you to someone that will answer any question.
    While I don't have a slider, it seems that you did it correctly.
    Jerry
    Good idea - thanks!
  • Nice thing about a B&W, is customer service. A quick call to them, gets a real person, that has the answers, or will quickly connect you to someone that will answer any question.
    Jerry
