abc40kids's avatar
abc40kids
Valve Stem Issue.....
So I'm upgrading to G rated tires and I ordered metal valve stems rated at 110psi. The problem is the rubber on the back of the stem wont go thru the valve hole on the wheel...
I also have rubber valves with metal sleeve rated at 80psi that fits... The E rated tires that came on my 5er were rated at 80psi so I'm thinking my G rated tires at 80psi will be much better than the E rated at 80psi. I'm not really wanting to go even 100psi on these stems rated at 80psi. What do you think....
I do have some other metal stems on the way today but they will probably be the same rubber. They make a 100psi rubber stem but once again the base is too wide. I did check my wheels and they are rated at 110psi.
