- minnowExplorerI've seen these apologists on Lippert supplied frames with these type of questions. The RV manufacturer gives Lippert the specifications and presto-changeo, frames start showing up at the RV manufacturers plant. Any issues with the frame is not because of the anything the RV Manufacturer has done wrong. Well I highly doubt that Lippert is just willy-nilly supplying frames based on an purchase order from the RV manufacturer. There's something called Product Liability and as Lippert has to warranty the frame, I'm positive that Lippert is very involved making sure the frame so requested will support the box being bolted onto it. Now how that frame is welded together and the experience level of said Lippert employees is another matter.
- memtbExplorerIf the manufacturer has a superior frame... you would think they would “tell the world” by singing it’s praises. If not...they say “nutt’n”!
- goducks10Explorer
ependydad wrote:
missourijan wrote:
If I were to purchase I would want to know what the specifications that Vanleigh gives to Lippert.
I can't fathom that a manufacturer would openly give that out.
I've asked manufacturers for pictures of the frames from the assembly line in order to get a visual on the cross-member supports and have difficulty even getting that.
Go to Northwood MFG's website and click on their Facebook page. They routinely feature their frames in a build photo shoot. I've seen several of their 5th wheel and TT frames on their page. I guess when you're proud of something you want everyone to see it. - ependydadExplorer
I've asked manufacturers for pictures of the frames from the assembly line in order to get a visual on the cross-member supports and have difficulty even getting that. - missourijanExplorerJust saying it's a Lippert frame isn't all the info a purchaser needs. Every manufacturer that uses Lippert frames gives Lippert specifications they want or use the standard frame Lippert offers. Drv requires a sturdier box frame but makes them heavier 5th wheels. If I were to purchase I would want to know what the specifications that Vanleigh gives to Lippert.
- batavia02ExplorerOops I looked for that info must have missed d it
- goducks10ExplorerPer Vanleighs website.
Exterior & Construction Features
Lippert Frame
Rota-flex Pin Box
8K Lippert Axles
Lippert Equaflex Suspension
Correct Track Alignment System
Lippert Automatic 6-PT Leveling
Westlake "H" Rated Tires
Generator Prep
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
