grampscamper's avatar
grampscamper
Viair 12 volt portable air compressor
I'm looking at purchasing a 12 volt portable air compressor. Our 5th wheel is in storage several miles from our home. When I go to pick it up after sitting for long periods the tires are down a few pounds. Now I carry a portable air tank with me but I can only add a few pounds to each tire. When we travel I carry a 120 volt compressor. I would like to purchase a 12 volt compressor so I can use it anywhere.
I'm presently looking at the Viair models 400P, 400P auto, 400PRV and 450P auto. I will be using it for my F250 & 5th wheel. The tire pressure in our 5th wheel is 80 psi. I'm leaning toward the 400PRV or 450P auto. The 400 series has a 33% duty cycle and the 450 100%. The price is the same for either.
Are they good compressors? Would 33% duty cycle be sufficient?
  • I've had a Viair 400 for over 7 yrs.
    Used it for 5vr tires (110#) and truck tires (80#).
    Great 12V DC compressor.
  • Yes, Viar makes some of the best small compressors out there.
  • RoyB's avatar
    RoyB
    Explorer III
    I have been using a like 12VDC portable unit for years back in my JEEP TRAIL days of the 60s up to present time with my OFF-ROAD POPUP trailer...
    This is the Q Industries portable MV50 12VDC 150 PSI Air Compressor available from AMAZON. It fits in its nice carry bag under my truck back seat. I usually sit this on my truck tailgate and hook into the trailer batteries and then I can use the provided long air coil hose to walk around the trailer and tires...
    I also use this air compressor along with the CAMCO 36153 Blow Out Adapter to blow out my water lines for winterizing. Being TANKLESS it takes more time to build up air compressor which is ideal for blowing out water lines.
    Perfect setup for me and my OFF-ROAD POPUP trailer.
    I got a new one in 2008 from AMAZON when I started pulling my OFF-ROAD POPUP trailer.
    You become king of the campground with all the kids and their bicycle when they find out you have a portable air compressor...
    Roy Ken
  • I have had the Vair 450P for 2 years and I like it. I like the auto feature.
  • I just did a search and found a recent post on the subject. I think I have the information I need. I may go with the RV model to get the extra air hose.
