oilslick wrote:
My 2011 ram 3500 is modified so extra power, 14,000GVWR trailer and I don't have an air suspension pin box, hitch at most rearward position. More importantly I remove my hitch very often. You being an installer I would very much like your opinion on MY method of installation.
With B&W's method I was concerned that the "u" bolts stretching and the lock nuts losing their locking ability and changing the friction applied with the set amount of torque would be a problem. Also the draw down bolt and nut stretch/torque.
I know that when the hitch is used with the 2 5/16 ball there is NO draw down torque applied to the lock pin, I have even heard of people forgetting to lock the pin in place on both the companion and the ball hitch. What I and many like me did was to install the thicker rubber feet then shim and torque the draw down bolt so that the lock pin can be easily slid in and out with the hitch just sitting there with no load, (just like the goose ball)then torque the "u" bolts. This means there is NO preload on the lock pin the same as with the goose ball. This also means the entire hitch can be lifted out in one piece with just drawing back the lock pin.
Dude there is NO stretch on the draw down bolt! If you have stretched it then you have over torqued it!
B&W will send you a strip to be placed on each side of the base plate to transfer the load to the low point of the bed and then the load is transferred to the hitch support. My 98 did not need this strip but my 11 did.
If the base is moving fore and aft when u are braking or accelerating then install the 5/16" or so thick strips B&W will provide to you. This will take care of the problem.
Other than that the hitch is un surpassed. IMHO
