rhagfo
Jul 05, 2019Explorer III
eurojet wrote:
I have been on a CAT scale and my pin weight after subtracting drive Axle with 5ER connected from just truck is 1660 pounds This was also with my old B&W Patrot hitch and not my new Pullrite Superlite which is a lot lighter
also my trailer weights 9540 pounds loaded so that would put me at 17.4% of a pin weight if i am doing my math correct
So I have a 2018 Crusader 30bh Pulled by a 2018 F150 3.5l eco SuperCrew with 3.31 rear end , 6.5' box
payload from Door sticker is 1812#
as per Fords 2018 towing guide my truck can town a 5er weighing max 10300# with a GCWR of 16100#
so my combination seems to work
GCWR is 15400#
payload/pin weight 1660# 17.4% pin weight
trailer weight is 9540#
Im even under my trailers GCWR UVW + CCC
My only measurement that was over was my Drive axle maximum weight i was over by 460#s , one of the reasons why i switched hitches and I removed so unnecessary things I dont use camping and also instead of using the residential queen spring mattress I bought a lighter Memory foam , I was also carrying 2 tool boxes one in my bed and one in the trailer , i have removed the Bed tool box so I can say i am maybe at this point only 200# over my rear axle ratings i do need to weight this new set up, but even if i am over my axle rating by 200# i am not worried
Clicky
Am I missing anyhting?
Well I would say no you haven't.
#1 You are weight aware, and working to stay close too ratings.
I am a firm believer that even over weight, towing a 5er is far more stable than a TT. I have never condoned towing over weight, even when I was doing it myself. No doubt that your 5er tows well, just watch your tire and wheel ratings.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
