okiejoe's avatar
okiejoe
Violentl vibration
I was leaving Branson Friday morning and as I left the campsite got on the highway and came to one of the down grades in the Missouri hills around Branson and stepped on brake as I decended down the grade and felt this violent vibration and immediately took foot off brake and it stopped, reapplied braked and again it happened. It did this on about 3 grades then I pulled over checked everything and saw nothing. Now I know the brakes need adjustment and my gain was up to 8.5 because of them being so in need of adjustment but just hadn't had time to get that done and this was just a short trip from home. Now I'm getting them checked out next week and in fact going to just have the axles serviced but going to have the Tech check it out real close but what do you all think happened. Now it wasn't the truck but the shaking was so bad it radiated into the truck. Give me your thoughts. Never had this happen before.
  • Warped rotor on disc brake probably. Fairly easy fix but feels bad. I'd suggest using your exhaust brakes or lower transmission gear downhill. Your brakes will last much longer and it's safer.
