Brandon327's avatar
Brandon327
Voltage backup camera
Does anyone know how the backup camera works? How to get it to display in the truck? I am looking at a used voltage and the current owner has never used the camera and doesn't know anything about it. We can't find any info on it.
  • In my Fuzion there is a switch in the garage on the wall that turns on power to the camera. See if yours has this setup. Mine is wireless also like what you described.
  • If it came standard with the Voltage TH then it is probably mfg. by voyager. There should be a wireless receiver that plugs into a monitor that works with the camera that somebody did not include? thanks my 2 cents.
    I have a voyager wireless camera on my 2011 Voltage and the receiver is located in my TV that plugs into my Garmin GPS.
  • It has it's own monitor that plugs into power outlet. It is around 8X8 inches and has a suction cup mount for the windsshield.
  • My guess is, if it is wireless it has its own monitor/receiver. If wired you will have to do some wiring before it will do anything. I haven't heard of a direct wireless to truck built-in... yet.
