Allworth
Jul 10, 2017Explorer II
You might try measuring from the input wire of the switch to a chassis ground. You should get battery voltage.
Then (with the pin in place) measure output wire of the switch to ground and it should be zero.
Pull the pin and output wire to ground should be same as battery voltage. i.e. there should be NO internal loss in the switch. If there is, the switch is defective.
A
A
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
