lightfoot's avatar
lightfoot
Explorer III
Sep 17, 2021
Voltage Dump Valve Replacement
I am looking to replace the manual pulls for the gray and black tanks with electrically operated valves. I need to know the size of the 2 existing valves so I can order the correct size replacements.
The trailer is a 2015 Voltage 3200.
  • Thanks for the replies, but one of you has to be right and the other wrong or maybe a combination. Have either of you actually done the valve replacement on a voltage?
  • black valves are all 4". I THINK the grey is 2". If you OD of ABS is about 1/4" more than "nominal" size (ie 4" ABS is 4 1/4" OD).
