- ksssExplorerI ripped the bottom off of the ladder on my 322. My new 342 has a ladder that folds against the trailer when not in use, you pull it out and repin it when you want to use it. This is a much better setup. Doesn't extend as low as the one I tore off and its always there if you need it.
- 2btowedExplorerTook mine off with an overhanging branch at Big Lake,AZ.Was not worth fixing,so I carry a Werner foldable ladder in the bed of TV.14 ft extended and holds 300lbs,works great to set up the zip line for the kids and I can put it where I need it.
- 2oldmanExplorer IIAs opposed to an inside ladder? :)
- aarondeereExplorerThanks for the offer. I never take it while camping and do have a large ladder so I guess I really don't need it.
- lightfootExplorer IIIMy ladder on my 3200 Voltage was bending at the bottom so I took off the last rung and solved the problem. I need a 2 step step stool to get on the ladder, but I was doing that before removing the last rung anyway.
- joebedfordNomad IIII'd give you mine if we were nearby. It's totally useless. I leave it at home.
- aarondeereExplorerYou tell me. I had it stored away in a shed hanging from a rafter and went camping. Come back home and find it in two pieces and no one knows anything. Yeah..... I'll get some pieces and put it back together.
- gscudderExplorerOur's is pretty flimsy too, the bottom is already starting to bend!!
- SpencerRBExplorer
aarondeere wrote:
Thanks. I'll give that a shot. The ladder broke in half where it mounts to the side of the camper.
Out of curiosity, how did it break? Hopefully you weren't on the ladder. Every time I go up/down that thing, I question its strength. - aarondeereExplorerThanks. I'll give that a shot. The ladder broke in half where it mounts to the side of the camper.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
