N-Trouble's avatar
N-Trouble
Walk-on roof really needed?
What is everyones opinion on having to have a walk on roof? My current WW Superlite is not a walk on and I've never really had a reason to get up there other than maybe cleaning out vents. The Attitude 5er I am looking at can come with either a standard or upgraded walk on roof which adds a side ladder and ~500 additional pounds.
  • I go up every time we pull in the slides. We didn't want slide awnings (camp in windy spaces) so I go up to clean off the slides and inspect the gaskets. I also inspect/clean the skylights, roof vents, sink vents, clean out the gutters to insure they work properly, inspect the a/c, and check the antennas. We don't want leaks and it seems the easiest way to avoid them is to frequently check where they might start. We also don't want birds, bugs, or bees building a nest up there. Our last tt didn't have a walk on roof nor a ladder and it was a royal pain to check anything. So we only did it about once every six months, when we had to. Now, going on the roof is like raising our jacks - something we do every time.
  • ..........Usually , you can tell where the seams are between the sheets of plywood ! Stay away from those seams , because that is the weak point on most Rv roofs ! You can feel the plywood bending down IF you step in the wrong place . , jf
