nickthehunter
Jan 24, 2023Nomad III
MarkTwain wrote:That's a good possibility. Sounds to me like you should be looking for a loose/barely holding on connection. Try pulling all the receptacles out of the boxes (if they have one) in the bedroom and check the connections.tourusa wrote:
Hi all I have a fifth wheel and Al the power went out except for the ceiling in the main bedroom around the nose and slide and ideas the 15 amp breaker is on and the gfi in the bathroom is on
The 12 volt lighting is working any ideas where to check
Yes, Unplug your electrical plug from the trailer and clean the trailer connections on the side of your trailer and then use some steel wool to clean connectors on the electrical cord. Blow out any debris. Plug in the electrical cord and remove, do it about 3 times. Then plug it back in. This should solve your problem.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
