moll672
Aug 11, 2015Explorer
Wall too hot next to fridge flue vent
Found that an area of the panel wall next to fridge vent/flue is getting very warm when fridge runs on propane. As a retired firefighter it is hot enough to make me concerned. Continual heating to a lower than ignition temperature can, over time, cause the ignition temp of a material to be lowered. The process is called pyrolysis. Temp was such that I didn't want to hold my hand on it for more than 2 seconds.
Had a look at flue from back side of fridge and it looks as though there is fibreglass insulation in the area of concern. Thinking that this is the problem by holding in the heat instead of a clear air space all around the flue pipe. Would have to take roof cap off to get at insulation, so not a 5 minute job. However seriously thinking this is the way to go as concerned about temp. Anyone out there come across same problem
