Desert_Captain
May 30, 2014Explorer III
ianmac23 wrote:Desert Captain wrote:
As noted it is easy to pull power from the nearest light fixture. Get the model th:Cat has the motor and fan up above and outside of the coach, they are much quieter.
Do you run the wire above and hide the wire or below the ceiling?
The wires from the light are spliced/tee'd into and run over to the fan control box inside the ceiling. When you are done nothing shows, makes for a very clean install. I would not spend the extra $$$ for the thermostat or remote models, our basic turn it on - off works just fine.
:C
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
