Zekeman's avatar
Zekeman
Warm water in faucets....
I know this has been posted a few times but I am at a loss. I have a 2006 open roads fifth wheel.
Last season we needed to replace the hot water bypass valve. This season when opened I'm only getting very warm water not hot. I have checked several things. The outside valves < shower> are closed. The bypass valve which we replaced is open, I even closed it and it did only produce cold water. Also went to hot water heater and released hot scolding water so I know it's producing very hot water. I have read it could be a cold water mix getting into the system but I checked the key critters and the external shower is closed and the hit water bypass valve is indeed fully open.
Any other suggestions?
  • happened to me. the third valve was down low and I had trouble seeing it and it was closed. couldn't really tell it until I held my camera in there and took a picture.
    bumpy
  • Do you have the one valve, two valve or three valve bypass system? The one and two valve systems both use a check valve and this may be the culprit.
