memtb wrote:
djousma,  The last part of your comment is very valid....I failed to mention that.  However....I was more "wasteful" than you. I probably sent a gallon or maybe more out the drain.  Call me paranoid!    ;)
Yep!  Thats my middle name.  We must be related.   Wyoming, Michigan, it gets pretty cold in the winter.  Dont need any surprises in the spring with any of the "fancy stuff".   Waterline to the residential refrigerator is another one.   That line runs from the heated basement area, outside the coach, back into the slide that the refer is located.   So, have to beware of camping in early spring or late fall where it gets below freezing at night.  That thin line will freeze pretty quickly where it is exposed to outside air.
