fallonator22's avatar
fallonator22
Washer and Dryer Advice!
We are looking to get a washer and dryer for our Sandpiper. I have read about both combo and stackable options and think stackable will probably be the best way to go. Just curious what everyone uses, how tall/wide they are, and how they work for you??
Also, I have read you have to have sewer connections for the stackable? If so, how would that work? I see where the water connections are, where you would drill for the vent in the wall...but other than that....??
  • Jim-Linda wrote:
    You certainly need sewer connection, water in washer has to go somewhere. Most have drain going into grey tank for shower/sink. we have Kenmore stack, 24" wide to fit thru entry door. It is a 110vac unit, drying is slower than household, but we are retired. If you have a space for W/D the height should be no problem. Would not be without one.
    Jim
    ok just saw that it does have the sewer connection. so we are looking at about 69" max - just need to do some research i guess! thanks!!
  • You certainly need sewer connection, water in washer has to go somewhere. Most have drain going into grey tank for shower/sink. we have Kenmore stack, 24" wide to fit thru entry door. It is a 110vac unit, drying is slower than household, but we are retired. If you have a space for W/D the height should be no problem. Would not be without one.
    Jim
