djousma
Mar 05, 2017Explorer
shepstone wrote:
What is the procedure for winterizing a washer/dryer unit?
varies by brand/type. I have the separate stackable units. For mine, you run hot water wash cycle until you see A/F in drum, then run drain/spin, then do the same for cold cycle, drain/spin. its important to run the drain spin, so that the drain pump gets A/F through it too.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
