lovemy5thwheel
Mar 05, 2017Explorer
Thanks for this. I never would have thought about the winterizing on a washer until the end of the season and then would not have know the proper way.
donn0128 wrote:
Same as winterizing your water lines. Blow out, pump antifreeze thru the lines. To reach the washer you start a cycle and draw antifreeze thru the washers water pump into the drum. Shut it off and your done.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
