rjxj wrote:
Often times when wet bolts are used, bronze bushings are also used. You might try lifting the rig so that the axles drop and try greasing again with the pressure off everything.
x2. That's a first step. Second step is to be sure that the bolts were put in so that the grease holes were horizontal. If they were put in vertically, then this is exactly what happens; the grease and dirt harden and plug up the grease holes. Also, I've =never= heard of a wet bolt kit that didn't have bronze bushings as part of the kit.
Lyle
