jktbExplorerFeb 13, 2017Waste waterI have a 2017 Jayco 5th wheel. Before departing the campground I open the black water valve, drain the tank then use the internal tank flush for 15 - 20 minutes. I then close the black and grey water ...Show More
sammytooExplorerFeb 14, 2017Do you have fresh water in your tank and have your pump turned on while traveling ? It could be leaking a little through a faucet or toilet valve.
Related ContentWater pump?Why no hot water?Waste water totes for fresh waterBlack Water waste valve leakingDraining fresh water (waste of water)
